How to connect 2 amps?
240sleeper
Posted: November 01, 2002 at 4:33 PM / IP Logged
Hi, I recently installed a xplode l600x, 6.5 speakers in the front and 4x6's in the back (all that fit).  Anyway what I wanted to do was install a small amp I had lying around to just power the 6.5's in the front because it is only 2 channel and non bridgeable then power the back ones through the deck.  I just bought a 12" sub and was wondering how to hook both the amps up to the deck.  There are only 2 rca plugs and obviously i need 4, is there a converter capable of doing this?  Thanks
bigwilley
Member - Posts: 16
Posted: November 01, 2002 at 6:28 PM / IP Logged
All you need is a couple of Y-cables - ones that have one RCA male plug and two RCA female plugs.  I've done this on many installs and have never had a problem.
