Ford OEM CD Unit
tronmonster
Member - Posts: 14
Posted: February 26, 2005 at 8:11 AM / IP Logged
I am attempting to use a Ford OEM CD Unit, model number F87F-18C815-CA, in a '95 Grand Marquis.
I bought an adapter harness from an on-line merchant because I did not want to go hacking into the wiring harness of my car. The problem I am seeing is terrible sound quality. It sounds tinny and has static.
I believe the head unit was from a late 90s model Explorer or Ranger. I believe the head unit is good, but there is something wrong with the power harness.
I was told the unit has a 24-watt output, and I am using the original speakers in the vehicle. They seem to be 4-ohm speakers.
Does anyone have any idea what the problem could be? Thanks in advance!
-tm-
Don't wanna hear your "boom-boom," just wanna hear my "weeee-yaaah-deedle-dee."
tronmonster
Member - Posts: 14
Posted: February 27, 2005 at 11:10 AM / IP Logged
Okay...maybe I am not asking the right question here. What I need to know is the pinout for the power connector on the above mentioned CD unit. Does anyone know where I can get that info? Maybe somewhere on this website (I have searched, but to no avail)?
-tm-
DYohn
Platinum - Posts: 10,741
Posted: February 27, 2005 at 11:26 AM / IP Logged
So the problem is which: poor sound quality or you can't figure out the wiring harness?  Also, does the Grand Marquis have the factory amplified "premium" system?
tronmonster
Member - Posts: 14
Posted: February 27, 2005 at 12:46 PM / IP Logged
DYohn, the car does not have the Premium System, just a run-of-the-mill, OEM, AM/FM Casstte. It sounds fine, for what it is.
The sound quality of the CD unit is bad, and I suspect it has to do with the power harness not supplying the correct inputs to the unit. I think if I knew what input each pin required, I could make the thing work correctly.
I believe the unit is fine, as I tried it in a late 90s model Explorer that had an identical unit. I removed the Explorer's original unit and popped mine in, and it sounded normal.
I am told that the unit has a 24 Watt output, so it seems to me it should drive the original 4 Ohm speakers in my Grand Marquis without any trouble. But, I am beginning to wonder if the Explorer has a power amp of which I was not aware. Perhaps the CD unit does NOT have a 24-Watt output??
So, I think that either there is a power amp necessary (which the Explorer has?), or my power harness is not powering up the unit correctly.
Thanks for your response!
DYohn
Posted: February 27, 2005 at 1:10 PM / IP Logged
If the HU powers up and functions, then it is being powered correctly.  There is nothing special about that HU, it is a Pioneer-designed Ford OEM part.  It is rated at 24 watts PEAK per channel (about 10 watts nominal) into 4-ohms and as far as I know is not normally used with outboard amplifiers.  The standard Metra 71-5600 into-radio wiring harness should work on it.
