2 SVC 4ohm speakers, Memphis 16-MC500D
skoldspuppy
Silver - Posts: 342
Posted: March 02, 2005 at 12:37 AM / IP Logged
Ok my brain is not working since its 1am right now
I have 2 SVC 4ohm speakers, I am going to wire them in parallel this will give me an impedence of 2 ohms right
now here where im having problems, I have Memphis 16-MC500D amp, it does 250X1 into 4 ohms, and 500X1 into 2ohms
the problem is where I connect the speakers I have 2 + and 2  -  but no marking for connecting a parallel wire
if memory serves me right most amps usally have it set up  the far left postive and the far right negitive is the mono/ bridge channel, but this one doesnt
Im lost... did I just end up buying the wrong amp?
Any help would be great
In peril
Skold
2004 Honda Civic Ex 4Dr
Kenwood DDX-7015/W Nav
4 Fosgate T152C
Hifonics Brutus BX1500D
RE XXX 12 in a 4 Cube Snail Shell
bdl666
Silver - Posts: 330
Posted: March 02, 2005 at 1:05 AM / IP Logged
It doesn't matter the dual + and - are there for ease of connection but it's just a mono amp. Both + and - are connected to the same place inside the amp. You can either connect each speaker to a set of connectors or wire them in parrallel and then just use one of the sets.
skoldspuppy
Silver - Posts: 342
Posted: March 02, 2005 at 9:14 AM / IP Logged
Cool thanks at around 4 am I realized that was the case, I was just way to tired to think last night
now im better
Oh someone go ahead and close and delete this post, Im all good now
Thanks again
--Skold
4 Fosgate T152C
