13w7, two amps
scerbyscerb
Posted: March 07, 2005 at 8:28 PM / IP Logged
yea i just recently got 2 jl 500/1 because i was going to run 2 10w7's but before i bought the tens i found a good deal on a 13w7 and got it.... should i use these 2 amps to power the 13w7. is it in any way safe for the sub??
thanks in advance
jeff
audiobass10
Silver - Posts: 328
Posted: March 07, 2005 at 9:00 PM / IP Logged
I forget the power handling on  a W7..what's it rated for?
Dave
Pioneer Premier DEH-P660
15" Kicker CVR
Profile AP1000M
It's Loud
scerbyscerb
Posted: March 07, 2005 at 9:02 PM / IP Logged
the 13w7 is 1000watts for the optimum range acorrding to jl audio's site
http://www.jlaudio.com/subwoofers/RP_Chart.html
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 07, 2005 at 11:31 PM / IP Logged
You should be fine. You would be puttin 500 at each voice coil which should be perfect.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
audiobass10
Silver - Posts: 328
Posted: March 08, 2005 at 12:50 PM / IP Logged
Yep, That'll work out real nice. Make sure you set the gains properly. Read a little bit and do it right.
Dave
15" Kicker CVR
Profile AP1000M
It's Loud
ctravis
Member - Posts: 31
Posted: March 08, 2005 at 2:12 PM / IP Logged
Be extreemly carful when hooking 2 amps to one subs dual voice coils.  even if they are the same make and model.  One amp could be outputting slightly more voltage than the other and the dual voice coils could end up working against each other.
Alpine Guy
Platinum - Posts: 2,478
Posted: March 08, 2005 at 5:15 PM / IP Logged
yeahh.... personally i would sell them both and get the 1000/1, , you should walk away with some cash in your pocket too, since i think 2 500's are worth more than 1 1000.
vinman75
Copper - Posts: 63
Posted: March 16, 2005 at 2:10 AM / IP Logged
You can use the two 500's you just have to set the gains with a multimeter so they are spot on.
specialblendj
Copper - Posts: 118
Posted: March 16, 2005 at 10:51 AM / IP Logged
A 13w7 can handle the power, you wouldn't be giving it anymore than what is recommended.  However, I would not hook up two amps to one sub.  Even if you use a meter to set your gains, I just wouldn't mess with it.  Even if you set the amp outputs the same, the two voice coils on the sub are not identicle in impedence.  The factory specs show that they are, but if you put a meter to them they are never exact.  I don't have a ton of experience to speak from, because I've never hooked two amps up to one sub, but I can tell you that to do so would be to contradict every article I've ever read on amp/sub wiring.
bullman96
Silver - Posts: 294
Posted: March 16, 2005 at 12:15 PM / IP Logged
you will be fine using the two amps.  set the gains with a dmm and you will be all set.  if you do a search for wiring two different amps to each voice coil you will find a more detailed explanation.  do not however bridge the amps together, the slightest difference will destroy the amps.  one amp to each coil
Pioneer PEH-9660mp
Mb Quart PCE-216 biamped
JL 12W6v2
Sony XM-4026 amp for tweeters
Kenwood KAC-7251 amp for mids
JL-4100 amp for sub
