mtx subs
mishkakasalapiy
Member - Posts: 27
Posted: March 11, 2005 at 3:37 PM / IP Logged
does it matter what volume of a box you make for the subs. what if its too bit or too small
DYohn
Platinum - Posts: 10,741
Posted: March 11, 2005 at 3:45 PM / IP Logged
Yes it matters.  The enclosure is as important as the sub you put into it and if it's too big or too small the performance can change significantly.
Start reading <HERE>
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: March 11, 2005 at 3:46 PM / IP Logged
It does matter quite a bit.  However you do have some flexibility in the enclosure size required.  You can vary the enclosure size by about 10% without an audible difference.  Stay within those tolerances and you should be fine.
Steven Kephart
Adire Audio
mishkakasalapiy
Member - Posts: 27
Posted: March 11, 2005 at 4:29 PM / IP Logged
how many cubic feet the box should be for 300-600W subs
Steven Kephart
Posted: March 11, 2005 at 5:52 PM / IP Logged
Each subwoofer is different.  It really depends on the theile/small parameters of the subwoofer.  Those parameters are usually supplied by the manufacturer.
Steven Kephart
Adire Audio
racer427
Silver - Posts: 381
Posted: March 11, 2005 at 6:22 PM / IP Logged
I agree with Steven, I am running 2 MTX 1004's in a .66 Cubic FT. per side, Enclosure. That is the mean size for those subs and they hit hard and sound clean. Check the Manufacture's recomendations for your particular sub.
  Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
