cva 1005 and no bass from sub
thinmyster
Member - Posts: 9
Posted: March 12, 2005 at 8:07 PM / IP Logged
hey im installing my alpine cva 1005 and for some reason when I plug my sub into the brain im not getting any sound from it? but all my other speakers are fine my amp lights up and when it was plugged into my last deck it worked fine.  Im a total noob at this so any suggestions or comments may help
thanks guys
Is there anything ihave to do on the deck to get it to recognize it?
geepherder
Platinum - Posts: 3,668
Posted: March 12, 2005 at 8:13 PM / IP Logged
Look in your manual.  If I remember correctly, the factory default setting on the sub out is the off position.  Go through the setup menus until you find it.
Chad7n7
Silver - Posts: 408
Posted: March 13, 2005 at 2:03 PM / IP Logged
I agree, Alpine's subwoofer default setting is OFF. In your manual, it should tell you how to adjust this. It is in the tone control settings IIRC.
thinmyster
Member - Posts: 9
Posted: March 13, 2005 at 9:51 PM / IP Logged
manual for the sub or the deck?
ill go look on the subs but just incase i cant find it?
thinmyster
Member - Posts: 9
Posted: March 13, 2005 at 9:52 PM / IP Logged
its a type r sub with a v12 amp?
Chad7n7
Silver - Posts: 408
Posted: March 13, 2005 at 9:56 PM / IP Logged
On your HU.
thinmyster
Member - Posts: 9
Posted: March 13, 2005 at 10:01 PM / IP Logged
sorry whats that mean? and its a mrp m200 amp
dont know if that helps?
thinmyster
Member - Posts: 9
Posted: March 13, 2005 at 10:02 PM / IP Logged
oh head unit?
geepherder
Posted: March 13, 2005 at 10:22 PM / IP Logged
Yes, my friend, on your head unit.  Sorry for the confusion.
thinmyster
Member - Posts: 9
Posted: March 31, 2005 at 10:28 AM / IP Logged
I have one more question when i open my unit i looks like it doesnt flip up all the way?  It perpendicular to me but looks like it should flip up a bit more.  Is there an easy fix to this? or is it supposed to be like this?  I can push the screen back aways using my hand so im almost positive its having some type of problem?
