dual voice coil?
crzycreations
Copper - Posts: 52
Posted: March 22, 2005 at 9:24 PM / IP Logged
hey guys, I know that dual voice coil subs can be wired parallel and in series and what not, but i was wondering if you can just power one voice coil at the rated rms without damaging the sub? I don't completly understand how speakers are made. So basically what i want to know is: does "dual voice coil" mean that there are just 2 different terminals to the single voice coil for wiring flexibility or are there 2 independent voice coils that have a power terminal for each?   thanks,
-Ryan
-Don't buy it, Build it-
haemphyst
Platinum - Posts: 5,059
Posted: March 22, 2005 at 9:58 PM / IP Logged
Two independent voice coils, electrically separate from one another. ...and yes, you can run one VC, and leave the other "free-wheeling", it will hurt nothing, HOWEVER, that being said, the specs of the driver will be different than the manufacturer will provide for you...
crzycreations
Copper - Posts: 52
Posted: March 22, 2005 at 10:04 PM / IP Logged
thanks haemphyst, i really apreciate it
DYohn
Platinum - Posts: 10,741
Posted: March 22, 2005 at 10:57 PM / IP Logged
And the power rating is usually halved unless it is listed as "per voice coil."
crzycreations
Copper - Posts: 52
Posted: March 22, 2005 at 11:19 PM / IP Logged
Sorry for my inexperience, but do you mean that it is halved if I only power one voice coil? for example: say I have a 4 ohm dual voice coil sub rated at 200 watts rms and i only power one of the 4 ohm voice coils, then I would only be able to put 100 rms to the one voice coil?
In essence I'm wondering if what you are saying is that you cannot supply the rated (200 wrms) to a single voice coil?
DYohn
Posted: March 23, 2005 at 8:22 AM / IP Logged
Yes, that's exactly what I'm saying.  But it depends on the woofer.  Some brands give power ratings "per voice coil" and others give ratings "with both voice coils wired."  If it's "per," then the listed rating would be fine into one VC.  If it's "both," then cut the number in half if using only one.
There are many reasons NOT to power only one VC other than power questions, not the least of which haemphyst mentioned: the Q (and other) ratings of the woofer will change and must be measured to build the correct enclosure.
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 23, 2005 at 8:28 AM / IP Logged
What would be a reason to only run one VC?
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
crzycreations
Copper - Posts: 52
Posted: March 23, 2005 at 9:17 PM / IP Logged
If I had a sub that's dual 4 ohm and have an amp that can put out the rated rms at a single 4 ohm.
Before I knew much about audio and wiring I put a dual voice coil sub into a powered home sub whos amp only put single 4 ohm, and i guess that's why it sounded so crappy.
I also was just kind of curious. I now understand, thanks guys
sorry if the question was stupid, that was just one part that i didn't quite understand yet, and hopefully the last lol.
thanks again
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
