Houston, problemo here, Bazooka amp
uthinkuknoaudio
Silver - Posts: 760
Posted: March 23, 2005 at 9:03 PM / IP Logged
Hey i got this bazooka EL1500 amp rigged up temporarily right, cuz i got no brahmas and no need to use my ZRS-9... and suddenly when i turn on the head unit (Nakamichi of course) the subs make a popping noise. At first i'm like wtf man, and i go back and look and see if theres any connection error. Nope, so i grab my remote, open the tailgate, and watch the amp turn on as i turn the head unit on from the back of the car. The protect (RED) light is on and the amp won't even turn on... Any suggestions?
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
ss-installer
Silver - Posts: 444
Posted: March 23, 2005 at 9:46 PM / IP Logged
check ground for good chassis connection. you should be getting remote since the amp is trying to turn on. how many amps are you running? fuse in side of amp good?
uthinkuknoaudio
Silver - Posts: 760
Posted: March 23, 2005 at 10:07 PM / IP Logged
2 amps. Fuses are fine. The amp worked fine when i turned the car off. Turned it on, and voila. It no work. The Red light is on though...
uthinkuknoaudio
Silver - Posts: 760
Posted: March 24, 2005 at 8:13 AM / IP Logged
bump.
actionjackson
Copper - Posts: 59
Posted: March 24, 2005 at 8:25 AM / IP Logged
Could be a blown sub, check the ohm of the subs with a meter
Jamie Jackson
*CRIMPING AINT EASY*
uthinkuknoaudio
Silver - Posts: 760
Posted: March 24, 2005 at 8:30 AM / IP Logged
Not a blown sub. Checked...
DYohn
Platinum - Posts: 10,741
Posted: March 24, 2005 at 9:42 AM / IP Logged
1) Disconnect the subs and see if the amp comes on without the protection light.  If it does, the problem is in your sub or wiring.  If not
2) Disconnect the RCA cables AND the subs and see if the amp powers on.  If yes, then the problem is in your RCA cables or your head unit.  If no, the amp is toast.
uthinkuknoaudio
Silver - Posts: 760
Posted: March 24, 2005 at 6:08 PM / IP Logged
The Amp was toast, fried, extra crispy. My EL1500 now works at KFC.
kfr01
Gold - Posts: 2,121
Posted: March 24, 2005 at 6:16 PM / IP Logged
How did you fry it?
New Project: 2003 Pathfinder
uthinkuknoaudio
Silver - Posts: 760
Posted: March 25, 2005 at 12:03 AM / IP Logged
No idea. Just turned on the car and it didn't work. Prolly fried a circuit in it somewhere.
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
