wiring inside to outside sub box
03sdccfx4
Member - Posts: 24
Posted: April 27, 2005 at 10:20 PM / IP Logged
As many of you know I am building  a wedge type enclosure for three subs that will fit behind the rear seat of my truck.
Even though it will be one big box it will have three compartments.   I would like to run the wiring through the inside to one end of the box.  Could I do this by drilling a hole in the seperators and run wire through them then seal it with silicone?  The wire I an using is round (streetwires 12ga twisted pair with an additional plastic over the pair making it round).
Then to get the wire outside the box should I just use a terminal cup?  They seem so flimsy compared to the construction of the box, or are they small enough they don't affect the enclosure performance as far as flexing?
thanks guys
'03 F-250 CC Fx4
forbidden
Platinum - Posts: 5,354
Posted: April 27, 2005 at 10:23 PM / IP Logged
Drill hole and seal with silicone. In some cases it is a good idea to secure the wire to the inside of the box with a wire loop and a screw as well to keep the wire from being pulled on or out of the box.
03sdccfx4
Member - Posts: 24
Posted: April 27, 2005 at 10:26 PM / IP Logged
dang your fast.
Is that better than terminals?
'03 F-250 CC Fx4
forbidden
Posted: April 27, 2005 at 10:57 PM / IP Logged
In my opinion, yes.
racer427
Silver - Posts: 381
Posted: April 28, 2005 at 8:59 PM / IP Logged
I do the same thing, I secure the wires inside the box using loops and screws and to exit the box, I just drill as small of a hole as possable, run the wire through it and silicone the crap out of it. I have built 3 box's using the method and have yet to run into any problems.
Also, after the silicone has curred, I usually spray the inside of the box with a sound deadener spray or a rubberized undercoating spray for one to make sure that everything is airtight and two, to help keep reasonating tones inside the box to a minimum.
Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
