power wire thickness
derrickg
Copper - Posts: 119
Posted: May 02, 2005 at 11:14 AM / IP Logged
I WANTED TO KNOW IFI AM USING THE CORRECT GUAGE WIRE FOR MY APPLICATION I HAVE A 1200.1 JBL AMPLIFIER THAT IS 1200 WATTS RMS AND A POWER ACOUSTIK AMPLIFIER THAT IS 100 WATTS X4 RMS THEY BOTH ACCEPT 4 GAUGE WIRE I AM RUNNING 2 FOR GAUGE WIRES TO EACH AMPLIFIER AND GROUNDS ONE AMP HAS 3 40 AMP FUSES AND THE OTHER 2 30 AMP FUSES SHOULD I UPGRADE MY WIRE TO 1/0 GAUGE I AM GETTING A VOLTAGE DROP IN THE REAR THE FRONT OF THE CAR THE VOLTAGE IS 13.8 WHEN THE BASS HITS A DEEP NOTE FOR A LONG TIME THE REAR VOLTAGE IS 11.8 I AM USING A 2.4 FARAD CAP TOO
haemphyst
Platinum - Posts: 5,059
Posted: May 02, 2005 at 11:32 AM / IP Logged
Why are you shouting??? CAPS LOCK, MAN!!! Yes, the power cable you have is acceptable. As a better solution, a #2 from the battery, with a fused distribution block for the amps might work better for you. The number 2 should be fused at the battery for 225A, and you will have fuses rated NO HIGHER than 150A in the distro block. This might help with your voltage drop issue.
