radio install in a 97 diamante
snyderman5
Member - Posts: 32
Posted: May 11, 2005 at 12:20 PM / IP Logged
I want to do an install in this car which is very easy as far as getting to it and such but there is an extra black connecter with a single wire coming out of it. Whats that for and what is the purpose of 2 different size antenna connecters?
KarTuneMan
Platinum - Posts: 7,056
Posted: May 11, 2005 at 1:31 PM / IP Logged
disregaurd the single wire plug, and use the antenna conector that fits (the big one) tape up the other one.
I dont know why theres 2
snyderman5
Member - Posts: 32
Posted: May 11, 2005 at 1:36 PM / IP Logged
Do you think it has to do with the power antenna
geepherder
Platinum - Posts: 3,668
Posted: May 11, 2005 at 10:08 PM / IP Logged
Is it the only wire (yellow) in a 4 pin square harness?  If so, it's the steering wheel controls wire.  The extra antenna plug is because that car has a diversity antenna (two antennas- usually one up front, and one in back) for better reception.  Don't worry about it, just tape it up and use the one.
snyderman5
Member - Posts: 32
Posted: May 12, 2005 at 7:26 AM / IP Logged
ok thanks to all for helping me out
