SQ Question
Kawoogie
Member - Posts: 8
Posted: June 05, 2005 at 11:38 PM / IP Logged
Hello, I recently purchased a Diamond Audio D912D4.  I was wondering if anybody here has had any experience working with this woofer, and could recommend a SQ enclosure for it.  I ran it through WinISD and it seemed that an enclosure that is 2.526^3, with a 4.02 X 17.76 vent would give me a nice flat transfer function with nice low end extension.  I will be running it at 800 Wrms.  I would love some outside opinions and Ideas.
Thanks,
Lee
P.S.  The Theile/Small Paramaters are located at http://www.diamondaudio.com/products/pdfs/D9%20Woofer%20Tech%20Sheet2.pdf
haemphyst
Platinum - Posts: 5,059
Posted: June 08, 2005 at 7:00 AM / IP Logged
I'm workin on it... trying to find my JBL after a format...
Kawoogie
Member - Posts: 8
Posted: June 17, 2005 at 3:39 AM / IP Logged
Hey haemphyst hows it going?  Have you found your JBL?
Nodestiny
Copper - Posts: 85
Posted: June 17, 2005 at 10:37 AM / IP Logged
WinISD works great. Though remember cabin gain plays a large role in car audio. honestly, in most car setups, it seems that a large sealed box is fairly unbeatable in SQ over even a good ported box. It takes a LOT of fine tuning and what not to get a low tuned ported box to sound truely good in the car... I would try out the recommended sealed box first, then compare to the ported and see what works better for you. My Matrix Elite subs sounded a lot better to me sealed than any porting i could do. They blended with my front end and had a cleaner drop than the ported... but everybody has their opinion... PLUS vehicle makes a differance as well.
04 dodge neon SXT
(2) Oz Audio Matrix Elite 12"s sealed in 4 cube fiberglass enclosure, powered by HiFonics BX1605D
Oz Audio Matrix 180cs 6.5" component set power by HiFonics ZX4000
haemphyst
Posted: June 17, 2005 at 10:51 AM / IP Logged
Yep... found it yesterday, but I was busy. I'll plug the numbers in tonight when I get home. Seriously, though, thanks for reminding me!
Kawoogie
Member - Posts: 8
Posted: June 18, 2005 at 3:35 AM / IP Logged
Nodestiny,  I agree with you that sealed enclosures sound really good.  My last few systems have all been sealed.  What made me want to try ported was a few things.  I heard the driver in a transmission line enclosure in the store and it sounded amazing.  Not exaclty what I will be building, but I was very impressed with it.  I have also never made a ported box before and am looking forward to the challange., and last, I want something that will go lower, and louder as well.  I find the sealed boxes don't always cut it.  But, if my ported doesn't sound good, I definitly will rip it out and build a sealed.
Cabin gain is one thing I don't know much about.  I have a background in electronics so I don't know much about acoustics.  I know it is usually around 50 Hz, but I don't know what it is for my car (92 Dodge Spirit).
haemphyst, thank you for offering to take a look at this.  Your input would be appreciated and respected.
Lee
DYohn
Platinum - Posts: 10,741
Posted: June 18, 2005 at 10:07 AM / IP Logged
I ran your woofer and came up with different numbers.  It looks to me like a 1.84 cuft (52.02 litre) enclosure ported for 27Hz is the best alignment.  The dimensions would be something like 21" X 17" X 12" (0.75" MDF) with a 4" port 21.25" long or a 3.5" port 17" long.  Realize that the T/S parameters given are with the speaker at 8 ohms (VCs in series.)  They do not give you the T/S at 2 ohms.  This speaker is best suited for a sealed application (0.9 cuft) however, as the EBP is 55.73.  It'll work ported and probably sound just fine.
haemphyst
Posted: June 18, 2005 at 10:43 AM / IP Logged
Those numbers came really close for me as well... My tuning hit at 28Hz, though... Close enough for government work...
Use the bigger port - less chance for port noise. Add additional space to the box to allow for the port volume. The volume DYohn came up with is NET volume, this means you have to know the displacement for all of your bracing, woofer volume, and port - then add it to the internal volume of your box. DO NOT SKIMP on bracing. This is especially important for a vented enclosure, as the pressures exherted are higher in a vented box at resonance than they are in a sealed box. Panel flex will also change your tuning. When you think you have enough bracing, find a way to add more to your design... If you think I am kidding, come over to my house and give a rap to the enclosure of ANY woofer here. They sound like you're knocking on stones. You CANNOT have too much bracing.
Kawoogie
Member - Posts: 8
Posted: June 18, 2005 at 3:03 PM / IP Logged
Thanks DYohn and haemphyst.   Ya, I noticed the EBP of 55.73.  i was hesitant to put it in a ported enclosure, but listening to the transmission line sold me.  How much of a difference will it make having the T/S parameters at  8 ohms instead of 2?  Not that I am concerned; I am just curious.  About the bracing, I am building this out of fiberglass, any hints, suggestions for bracing?  This is the largest fiberglass project I have undertaken yet, so anything will be helpful.  I have learned about improper bracing before in the past.  Trust me, I don't want to make that mistake agian.  Thanks
Lee
haemphyst
Posted: June 19, 2005 at 10:26 AM / IP Logged
I got nothin'... Maybe some others could help out. Personally, I have never undertaken any fiberglass projects. I'm escared... Just never had the time or desire, and never really wanted to do the "trick" thing...
