98 Honda Accord, no power to HU
trixreppinva
Member - Posts: 31
Posted: June 08, 2005 at 1:17 PM / IP Logged
A few days ago I was trying to put sunvisor t.v.'s in my car and I wasn't payin attention to what I was doing and I accidently stripped my power wire for my head unit while the unit was playing.  There was a spark and then my head unit stopped playing.  I tried unhooking it and then rehooking it and it still didn't work.  I bought a new head unit and the new still isn't working and neither is my ciggarette lighter.  It's just like nothing is getting any power.  So if anyone has any idea what the problem might be please let me know.  I would really appreciate the help.
trixreppinva
Member - Posts: 31
Oh yea I have a 98 Honda Accord
forbidden
Platinum - Posts: 5,354
Posted: June 08, 2005 at 1:24 PM / IP Logged
You more than likely have blown a fuse protecting the circuit. Check all fuses in the car and under the hood, especially the radio and dome light circuits.
trixreppinva
Member - Posts: 31
Posted: June 08, 2005 at 4:22 PM / IP Logged
I checked all the fuses and all of them seem to be o.k. any other ideas?
kd7nfr
Copper - Posts: 71
Posted: June 11, 2005 at 4:07 PM / IP Logged
Disconnect the battery and check for continuity from the positive wire in your dash to the positive battery terminal, if you get nothing, run a new wire. If you get something... Well... sell it and buy another?
samroza
Member - Posts: 43
Posted: June 12, 2005 at 8:16 AM / IP Logged
Fuse most likely. I know nothing about Hondas, but I know there are 2 separate fuse panels in some American cars, so dig around.
Sam Roza
Bumpin' Yota
Member - Posts: 9
Posted: June 12, 2005 at 8:36 AM / IP Logged
You popped a fuse - pull each and every one if you must, but I garuntee that you blew a fuse.  Also be sure to check underhood.  Many imports have a main fuse underhood that backs up your fuse panel.
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
kd7nfr
Copper - Posts: 71
Posted: June 12, 2005 at 10:04 AM / IP Logged
He could have melted the wire. Not likely, but possible.
burns25
Member - Posts: 49
Posted: June 12, 2005 at 10:15 AM / IP Logged
There's a fuse under the hood that is the main power fuse for the radio in honda's. It's back on the passenger side near the fire wall. It should be a 7.5 amp fuse.
auex
Platinum - Posts: 5,041
Posted: June 12, 2005 at 11:37 AM / IP Logged
If the wire you were tieing into was WHITE/ blue then this is the solution.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
