Stuck, routing speaker wire
Jvee
Member - Posts: 26
Posted: June 16, 2005 at 10:38 PM / IP Logged
I have ran into a snag.  I am bi-amping components into front doors and there seems to be no way to get the wires through the factory rubber hose connecting door to body.  I don't know if I could get one wire through, let alone two.  I already did the rears - difficult, but done.  Now I am stuck.  Can I go outside of the tubes and then cut into the seals at both ends, or will that get me into more trouble.  Any help/advice would really be appreciated.
nguyenk
Member - Posts: 31
Posted: June 16, 2005 at 11:13 PM / IP Logged
What car? Sometimes you can push the wires through using a sharp point like a tip of a screwdriver. Just be careful. If not, do what you say and put some silicon caulk around to seal it.
stevdart
Platinum - Posts: 5,816
Posted: June 16, 2005 at 11:28 PM / IP Logged
Sure, you can drill new holes for it.  Use a length of small diameter rubber hose and slip it over the wire with the door open, and after the wire is inserted into the door push both ends of the rubber hose firmly into the two holes.  Or you can use grommets for the holes...or the dirty way is to wrap the wires in electrical tape and use silicone caulk in the drilled holes.  Just as long as the wires are protected from abrasion.
SoundAudio
Copper - Posts: 242
If you absolutly can not fit it through the factory boot, you can always purchase a boot that is similar to factory on to run your speaker wire through or just as you described cutting into the seals.  It is wise to silicon the area around the speacker wire and the seal and make sure you run from high at the car body to low at the door so any water might run into the door not the kickpanel where many important vehicle electronics are placed.  Good Luck!
Jvee
Member - Posts: 26
Posted: June 16, 2005 at 11:34 PM / IP Logged
Thanks...     Stevdart, I am assuming that rubber hose is a good idea just to help with the seal overall.  I am using twisted speaker wire so the outside layer should provide some protection for speaker wires.
jussam
Copper - Posts: 78
Posted: June 17, 2005 at 1:48 PM / IP Logged
get yourself  fiberglass fish cable and a little gel and you should not have any trouble getting wires through boot take your time. the boot made be  ribbed and that's where your getting snag
2-alpine amp mrv-f545 4ch amp
polk audio 6 1/2 frontdoor w/alpine center speaker
polk audio 6 1/2 rear w/8"polk sub
2-12" alpine X type sub
2-alpine mdr-1005 amps
Jvee
Member - Posts: 26
Posted: June 20, 2005 at 10:22 PM / IP Logged
Thanks all.  I cut new openings in the rubber boots and actually used a 26" road bike inner tube to insert wires and seal holes.  Since I was bi-wiring, I don't know how else I would have done it.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
