pioneer deh-p80mp sound prob
joe_1
Silver - Posts: 286
Posted: June 20, 2005 at 4:37 PM / IP Logged
when the volume is turned up over 30 the rca outputs turn off for the front and rear the sub stays on butt it only happens when there is a cd playing when its is on radio it is fine and i have tried other discs and still does the same.
Lthlquicksilver
Member - Posts: 47
Posted: June 20, 2005 at 5:33 PM / IP Logged
Your amp may be going into protection mode.  When it happens, check the amp and see if it's still getting power.  It may just be turning itself off, which could lead to a wiring problem to the amp (most likely a ground issue).
Muscle Cars Don't Just Look Good, But They Can Sound Good Too...
1971 Chevelle SS
outlaw000
Member - Posts: 42
Posted: June 20, 2005 at 5:54 PM / IP Logged
if you have three amps your probably gonna need a relay for the remote wires, to check this use a multimeter at the remote terminal to verify there is still 12 volts when the amps shut down. Also check for any lose copper strands at both the radio and amps speaker terminals.
joe_1
Silver - Posts: 286
Posted: June 24, 2005 at 5:33 AM / IP Logged
i did check all that before i put the post up it was all ok on the settings of the stereo it had sla level i turned this down and now it is ok thanks for the help guys will let you know how it goes.
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
