will i break auto glass ?
Blowntweeters
Silver - Posts: 650
Posted: July 14, 2005 at 9:41 PM / IP Logged
i am going to be installing 2 15" soundstream XXX subs and 2 XXX amps with an 250 amp alternater just for the system with 4 kinetik batterys and the inside of the vehicle will be sprayed with rhino lining this is going in a 97 suburben the amps are rated at 6500 RMS each and the rated power handling of the subs is 8500 RMS the ? will we break any windows and if we    do does any one know were i can get stronger auto glass
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
jettadude
Member - Posts: 7
Posted: July 14, 2005 at 10:45 PM / IP Logged
if your breaking glass you might wanna install plexi insed
Poormanq45
Silver - Posts: 597
Posted: July 14, 2005 at 11:25 PM / IP Logged
lexan.
You may break windows . It depends on the frequencies you're playing
jettadude
Member - Posts: 7
Posted: July 14, 2005 at 11:28 PM / IP Logged
some laxan doesn't like UV light. and its expencive
Drewt
Copper - Posts: 183
Posted: July 15, 2005 at 12:49 AM / IP Logged
with 2 15" xxx subs and 2 xxx amps, price isn't gonna be much of a factor :)
-Drew
speedwayaudio1
Silver - Posts: 879
Posted: July 15, 2005 at 5:27 AM / IP Logged
laxan is easyer to work with. it drills better and doesnt chip. wonderful stuff. I use it alot when building our stock cars. it will even bend in a pan and box break. depends on thickness. I make wind screens, side skirts, rear spoilers.......you name it.
Big Dave
nowlater123
Copper - Posts: 61
Posted: July 15, 2005 at 10:21 PM / IP Logged
Polycarbonate.
It's expensive, but almost impossible to break. And, it is UV tolerant. It is probably your best bet.Your just have to custom order it for your car.
Kenwood all the Way!
Blowntweeters
Silver - Posts: 650
Posted: July 16, 2005 at 9:26 AM / IP Logged
Thanks for the info everybody
haemphyst
Platinum - Posts: 5,059
Posted: July 16, 2005 at 10:07 AM / IP Logged
ALL of the plastic solutions mentioned will be short-lived, also. Nobody mentions how easily all of these types of plastic scratch. After maybe 3 or 4 automatic car-washes, they're gonna be all hazy from the scratches in 'em. Also, are you planning on replacing the windshield? Illegal, my friend... That also has the additional wear and tear of the wipers to contend with. What it SOUNDS like you are trying to do, does not seem very likely for a car you want to keep on the road (legally), as a daily driver.
Honestly, though, I don't think two woofers are going to be able to produce THAT kind of (music) SPL, anyway... no matter HOW much power you feed to 'em. Steady state? Possibly... but that's just my personal opinion. While it is more likely you will pop seals, breaking the actual glass? I don't see it happening.
....16
Blowntweeters
Silver - Posts: 650
Posted: July 16, 2005 at 10:19 AM / IP Logged
ya this  is not going to be a daily driver but it will be at a lot of local comps for display
