Do i need a relay?
pain_is_lov3
Member - Posts: 27
Posted: November 30, 2002 at 11:29 PM / IP Logged
I have an EQ and 2 amps to hook up.  So can i just use the remote turn on from the head unit or do i need a relay?  If i dont need a relay then how would i wire the amps and the EQ up to the remote turn on wire?
djfearny2
Silver - Posts: 810
Posted: November 30, 2002 at 11:47 PM / IP Logged
well a relay will protect your remote turn on but it should not be neccesary . but if you want here is how to do it.
pin 85 positive input from radios remote turn on
pin 86 ground
pin 87 constant 12 volts fused at ten amps or five
pin 30 output to all the components amps eq  etc. pin 87a not used
now if somethign happens you will not damage the radio you will just blow the fuse you add on to pin 87
Jon
Installer/Help Technician
---coral springs florida---
bberman1
Gold - Posts: 2,314
Posted: December 01, 2002 at 11:30 AM / IP Logged
Like djfearny2  said for that setup you don’t need to install a relay.
OmarZ
Member - Posts: 8
Posted: December 01, 2002 at 1:41 PM / IP Logged
When would you need a relay there and how do you know?   The same setup with a power antenna? (and no antenna output on the deck)  What about number of amplifiers to be turned on?
pain_is_lov3
Member - Posts: 27
Posted: December 01, 2002 at 8:42 PM / IP Logged
Ok i dont need a relay so how would i wire all those up to the remote turn on?
bberman1
Gold - Posts: 2,314
Posted: December 02, 2002 at 1:56 PM / IP Logged
Just take the remote turn on and solder or crimp all of your connections together. As far as a relay goes I like to use on when ever I have more than 4 connections to my remote turn on.  But if you have a power antenna and no antenna turn on then defiantly use a relay.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
