Bass blockers on an amplified system
bigmikeww
Copper - Posts: 75
Posted: August 10, 2005 at 9:18 PM / IP Logged
I got a pioneer 2 ch amp running 2 ohm stereo. getting a little to much bass for me. i have a couple of 22uF 100v crossover capacitors. if i put these on the positive side of each speaker will it cut off more bass? or should i put one per pair? and suggestions or comments would be appreciated
mike
bigmikeww
Copper - Posts: 75
Posted: August 10, 2005 at 9:23 PM / IP Logged
forgot to let you know that is amp is running my mids and highs.
DYohn
Platinum - Posts: 10,741
Posted: August 10, 2005 at 10:32 PM / IP Logged
If the amp has a built-in high-pass filter that will be more efficient than using bass blockers.  22 microfarads on 4-ohm speakers will do a lot more than block bass, that would create a 6db/octave high-pass filter at about 1800Hz.  WAY too high, and at 2 ohms it'd be in the upper midrange at around 3600Hz!  You want to cut frequencies below about 100Hz.  To do that with a capacitor ar 2 ohms will require 800 microfarads!!!
bigmikeww
Copper - Posts: 75
Posted: August 10, 2005 at 10:55 PM / IP Logged
in the amp theres only a low pass filter. when i ordered the filters they were recomended for 3.5, 4, 4x6?
DYohn
Posted: August 10, 2005 at 11:42 PM / IP Logged
You could try an F-Mod filter if you want, or an electronic crossover.  I'd recoment that before using "bass blocker" capacitors.
