Pioneer Premier TS-SW124D
minytrker
Member - Posts: 25
Posted: August 22, 2005 at 2:07 AM / IP Logged
I am thinking about buying this sub for my 02 Z06 corvette for the center storage compartment in the back. The only draw back to this sub is the 4ohms. I'm not looking to spend a lot of money on this system either. I have been looking for a small amp that pushes around 400rmps@4ohm. I can get pretty much any of those for around $200 and the sub for about $100. Is there any other amps that are better and which is the best out of those? Or should I choose a 2ohm sub?
MA Audio HK800D
Diamond Audio D3400-2
Phoenix Gold R4.0.2
Pioneer GM-5100T
dwarren
Posted: August 22, 2005 at 2:30 AM / IP Logged
I like the two in the middle of your list, Pioneer doesn't thrill me with their amps and that MA stuf is coming close to flea market gear.
I don't think there is anything wrong with running a sub setup a 4 ohms, especially a non digital amp. I am not sure where you got this notion of anti 4 ohm and only 2 ohm stuff.
If you find a sub that is 4 ohms and an amp that produces sufficient power at 4 ohms, you should be golden. Running amps at greater resistances only makes them work harder, hotter, shortens the life span, and can introduce more THD, even if they are rated at 2 ohms or below.
minytrker
Member - Posts: 25
Posted: August 22, 2005 at 10:49 AM / IP Logged
Thanks. I have always had real high powered systems that were at 1ohm most of the time. I have had mostly systems in the 4000 watt rms range. I just didnt want to spend $10,000 on a system again.
