how to wire up subs to amp
KumpleteKustomz
Posted: August 22, 2005 at 9:52 AM / IP Logged
i have two 4 ohm dvc directed audio subs that are 600 rms watts and my amp is a diesel audio 1800 and it says power output @ 2 ohms 900w x2 and @ 4 ohms 450w x2 now how can i hook my subs so hey are 2 ohms .
stevdart
Platinum - Posts: 5,816
Posted: August 22, 2005 at 10:06 AM / IP Logged
Each sub will be 2 ohms by paralleling the coils.  Put a sub onto each channel for a 2 ohm stereo output.
What I would do, though, is series the coils to make each sub 8 ohms, then parallel the two subs together and bridge the channels with the 4 ohm load.  That is a 2 ohm output, as well, and the result will be mono.
https://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
godblessdremil
Silver - Posts: 273
Posted: August 22, 2005 at 10:11 AM / IP Logged
Since they are 4 ohm dvc you need to run a wire from the positive of one coil to the other, and the same with negative. Then just run a wire from one of the negative to the negative on the amp, and the same with positive
        +0   -0
Sub     |    |
        +0   -0
AMP      +    -
