05 Ford Taurus - upgradeable?
angelob
Posted: September 05, 2005 at 10:10 AM / IP Logged
I just bought an 05 Taurus and was wondering if this stereo is upgradeable?  I'm looking to put my old Alpine head unit in it.  Are there dash kits available for this - if so, where are they available?
Thanks,
Angelo
jettagli03
Copper - Posts: 311
Posted: September 05, 2005 at 10:29 AM / IP Logged
they're everywhere -- just search online and you're bound to find many. i installed one in my friends car and picked him up one from best buy (he paid me back) and it wasnt cheap, like $150
Hornshockey
Silver - Posts: 520
Posted: September 05, 2005 at 11:19 AM / IP Logged
So someone's finally got a fix for the Air Bag light issue?  Or did Ford change from 04-05 and move the light off the panel with the radio and HVAC controls?
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
angelob
Posted: September 05, 2005 at 12:20 PM / IP Logged
The air bag light is still there - just saw it.
daze
Copper - Posts: 112
Posted: September 06, 2005 at 8:01 AM / IP Logged
I have heard of guys using a resistor to trick it... As far as i know it works. I do not do that because what if the resistor shorts ?? Air bag light !
angelob
Posted: September 06, 2005 at 10:52 AM / IP Logged
I've done a search and it appears that a 10k ohm resistor is being used.  Does anyone know what wattage resistor to use?  1/4 watt, 1/2 watt, etc.??
stevdart
Platinum - Posts: 5,816
Posted: September 06, 2005 at 11:55 AM / IP Logged
I'm not familiar with either that problem or solution, but as far as your wattage question goes:  it doesn't matter.  You'll probably find the most selection in  1/2 watt or 1 watt resistors.   See http://www.bcae1.com/watt.htm
Hickmanae3
Copper - Posts: 67
Posted: September 06, 2005 at 3:06 PM / IP Logged
So my question is if the air bag light is trip, would the air bags blow?
No security system can beat the tow truck :(
stevdart
Posted: September 06, 2005 at 6:10 PM / IP Logged
No way, it still requires the force of a crash.  If that were the case you would be replacing air bags every time you disconnected the battery.
Hornshockey
Silver - Posts: 520
Posted: September 07, 2005 at 1:24 AM / IP Logged
No; the air bags won't blow; but rather it will have the opposite effect.  The system will see a problem and put on the air bag light.  The system will disable the airbags since there is some problem with the system to avoid a possible malfuntion and accidental deployment.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
