2000 S10 Stereo Wiring
ktmorgan
Posted: September 24, 2005 at 11:16 AM / IP Logged
I have a question maybe someone can lead me in the right direction or help me out. I need to know the stereo wiring on a Chevy S10. You know what the colors mean and everything like that. If anyone could help that would be wonderful.
Thanks,
Theresa
tcss
Silver - Posts: 1,623
Posted: September 24, 2005 at 11:48 AM / IP Logged
Orange 12volt constant, yellow 12volt switched, black ground, gray illum.,lt green RF+,dk green RF-, tan LF+, gray LF-, dk blue RR+, lt blue RR-, brown LR+, yellow LR-. Sometimes the 12 volt switched is dk green, but you can tell which one it is because it's next to the constant.
ktmorgan
Posted: September 24, 2005 at 12:10 PM / IP Logged
Ok, This is the problem I'm having. I have a red wire on the stereo I just bough and it said it was a Turn On +ACC Now do I hook that up to my orange wire. I don't have any red wires. So that is what is tripping me up. Thank YOU SO MUCH!!
Theresa
tcss
Posted: September 24, 2005 at 12:29 PM / IP Logged
No, the red lead should go to 12 volt switched. The orange on the truck should go to the yellow on the deck.To make easier, go to a stereo shop and get a Metra 70-1858 harness. This will match colors for you.
ktmorgan
Posted: September 24, 2005 at 12:34 PM / IP Logged
Ok Thank You I was just matching color to color, and that was about it. HA!2000 S10 Stereo Wiring -- posted image.
So does it matter that when I took my other stereo out that I cute the little plastic pieces off it that was holding the wires?
Thanks for all your time and help today!
tcss
Posted: September 24, 2005 at 12:50 PM / IP Logged
No as long as your new connections are well insulated. I use crimp caps but "butt connectors" will work well too.
