Soundstream 705s. Wiring in a single sub?
london luke
Member - Posts: 28
Posted: October 05, 2005 at 5:21 PM / IP Logged
havin th esystem installed soon. I am buying off the installer a single Aliante 10.inch subwoofer.
4.ohm.  Can the amp mono outputs  run bridged??
cheers
Blowntweeters
Silver - Posts: 650
Posted: October 05, 2005 at 5:26 PM / IP Logged
the mono out put is only 1 channel. you cant bridge that.
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
london luke
Member - Posts: 28
Posted: October 06, 2005 at 2:14 AM / IP Logged
It has 2 x mono outputs.
wondering if both mono can I still bridge?
Blowntweeters
Silver - Posts: 650
Posted: October 06, 2005 at 1:07 PM / IP Logged
i would call soundstream
london luke
Member - Posts: 28
Posted: October 06, 2005 at 2:36 PM / IP Logged
Soundstream dont answer phone or emails. heard they are bust
london luke
Member - Posts: 28
Posted: October 06, 2005 at 4:12 PM / IP Logged
Soundstream 705s. Wiring in a single sub? -- posted image.
In th epic you can see that each mono speaker connector has a + and a - . So by using the "Hot +" etc and the other - would this in effect bridge the amps??
Cheers
rallysport
Copper - Posts: 172
Posted: October 06, 2005 at 4:21 PM / IP Logged
if its a mono amp there is only one channel of output, mulitple connects are there for easyier hookup, internally both connection points are connected. same as asked here https://www.the12volt.com/installbay/forum_posts.asp?tid=63896&PN=1
london luke
Member - Posts: 28
Posted: October 06, 2005 at 6:01 PM / IP Logged
Starting to understand.. !! I want to get as much power out of it to run my Aliante 10 inch subwoofer.
