best amp for 2-12 RF Punch stage 1 subs?
pznat
Member - Posts: 34
Posted: October 06, 2005 at 4:13 AM / IP Logged
I am wondering if anyone could give me some ideas on what amp i should buy to power two 12" Rockford Fosgagte Punch stage 1 subs. i want to get the most out of the subs since they are in a relatively small sealed box(.68 cu ft). looking for something relatively inexpensive that still provides all the power they can handle.
thanks
P
SUB Specs:
# 12" 4-ohm subwoofer
# molded polypropylene woofer cone with foam surround
# frequency response: 20-200 Hz
# power range: 50-150 watts RMS
# peak power handling: 300 watts
# sensitivity: 86 dB
# top-mount depth: 5-3/8"
# sealed box volume: 1.25 cubic feet
# ported box volume: 1.75 cubic feet
_P Griff
pznat
Member - Posts: 34
Posted: October 06, 2005 at 4:18 AM / IP Logged
that sealded box volume is .68 cu ft per sub side
here is a pic of the box the subs are in
best amp for 2-12 RF Punch stage 1 subs? -- posted image.
_P Griff
blazeronspokes
Copper - Posts: 102
Posted: October 06, 2005 at 10:02 AM / IP Logged
you should be able to go with the rockford 3001 mono amp. i sell that setup all the time and it sounds pretty good for the money.
skoldspuppy
Silver - Posts: 342
A JL 250/1 will give them 125watts a piece, plenty of jucie to get them moving
A Memphis 16-MCA300 will put 150 watts a piece to them
There about 5,000 other Amps that will work as well, whats your budget?
Later
--Skold
2004 Honda Civic Ex 4Dr
Kenwood DDX-7015/W Nav
4 Fosgate T152C
Hifonics Brutus BX1500D
RE XXX 12 in a 4 Cube Snail Shell
pznat
Member - Posts: 34
Posted: October 06, 2005 at 12:02 PM / IP Logged
I am looking to try to get a steal on someting around $150-$180
_P Griff
Blowntweeters
Silver - Posts: 650
Posted: October 06, 2005 at 12:59 PM / IP Logged
if you want a steal .check out www.ikesound.com there is a lot of mono amps. that will fit the bill for less than that.
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
alpine_king
Copper - Posts: 73
Posted: October 06, 2005 at 8:02 PM / IP Logged
if you really want to get them going you are prolly gonn ahve to spend more then that.
1993 Ford Ranger.
Head Unit.Alpine CDA-9831
Front Speakers.Infinity 6010 Reference Series
Amp.Alpine MRD-M1005
Subs.3 Kicker CVR10
Rear Speakers.SPL CS-573
20" Boss 312's, lowered 3/4
