lights dim 2nd battery
qmw54
Copper - Posts: 54
Posted: October 09, 2005 at 2:28 PM / IP Logged
my lights flicker when my subs hit ... and i was wondering if i put a 2nd batt in my 99 silverodo and just hooked up my amp to it would it solve the problem .... or can a stock alt. hand charging 2 batts. ??
thanks qmw54
Bigsingh
Copper - Posts: 204
Posted: October 09, 2005 at 2:41 PM / IP Logged
shud be fine wioth a second batt
6* Rockford T2's
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
footbaldd
Copper - Posts: 84
Posted: October 09, 2005 at 9:15 PM / IP Logged
As far as I know adding a 2nd battery will actually put more load on your alt, so if it was me I would save the money and get an ho alternator.
arrow12
Silver - Posts: 527
Posted: October 09, 2005 at 9:39 PM / IP Logged
go with a an HO alternator because your second battery will drain quickly.
That's my opinion. Take it, leave it, or correct me.
qmw54
Copper - Posts: 54
Posted: October 10, 2005 at 11:27 AM / IP Logged
...... i dont kno what a good alt would be .... i am running a sony xplod 1200 with two 350 watt 10's but i plan to ugrade to some 450 or 800 watt 12's .... dont really kno what the right size alt or price would be ... thats where yall come in any names ... sites .... prices .... would be very helpful
thanks qmw54
Bigsingh
Copper - Posts: 204
Posted: October 10, 2005 at 11:59 AM / IP Logged
if you're running these kinda wattages your battery should be fine. rather than going to the extra expenditure, why not jus get a cap. but i think a second battery shouldn't put too much of a burden on ur alternator. no need for a better alternator
6* Rockford T2's
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
evanc
Copper - Posts: 148
Posted: October 10, 2005 at 12:08 PM / IP Logged
I'd stay away from a cap and a battery.
An additional battery will just help if you are playing your music with the car off for long periods of time, which doesn't appear to be what the problem is.  Your lights are flickering because they are pulling more current then you have available, thus your lights are not getting enough current (as are other parts of your car) to make up for it.
I would get a meter out and test all the connections and make sure everything is grounded correctly.  If all that checks out, you will need a higher-output alternator.  For the size of the alternator, I would just go with the biggest you can fit in your vehicle without any modifications so if you upgrade your system later, you won't be lacking in the charging department.
sneakycyber
Silver - Posts: 413
Posted: October 10, 2005 at 12:37 PM / IP Logged
Agreed, adding a second battery is not going to solve your problem.. A cap would be just a bandaid to the situation look at getting a high output alternator.
alpine_king
Copper - Posts: 73
Posted: October 10, 2005 at 1:28 PM / IP Logged
yah a cap is only good when you have the power to store, and in your situation it sounds like you dont have the power in the first place. ho alt for sure, and if you plan on upgrading to two 12's 450 or 800 watts? you will definatly need a better amp man.
1993 Ford Ranger.
Head Unit.Alpine CDA-9831
Front Speakers.Infinity 6010 Reference Series
Amp.Alpine MRD-M1005
Subs.3 Kicker CVR10
Rear Speakers.SPL CS-573
20" Boss 312's, lowered 3/4
forbidden
Platinum - Posts: 5,354
Posted: October 10, 2005 at 3:30 PM / IP Logged
Read the groundng sticky at the top of the forum, it applies to you for sure.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
