box volume
markb
Member - Posts: 43
Posted: December 09, 2002 at 10:26 AM / IP Logged
I'm trying to squeez two 8" Cerwin Vegas into a very tight spot. They require .5 cu.ft. per woofer, and I'm making one box for them to share. The most volume I can get is about .45 cu.ft. per chamber in the space I have. Is it possible to "fool" the woofers into thinking they are in a bigger enclosure by using polyfill? If so how much?
-Mark
bberman1
Gold - Posts: 2,314
Posted: December 09, 2002 at 12:02 PM / IP Logged
Yes you can fool it by filling it with the Polly fill. I like to stuff the box about 50%
NyxBass
Silver - Posts: 226
Posted: December 09, 2002 at 8:16 PM / IP Logged
Yes, about 50% full of polyfill, or 1lb per cubic foot is another guideline. I think with that small of a difference (10%), you shluod be alright, the response will be  tad bit tighter, with a little more peaked low mid response - I'dgive you a plot if I were on my machine, bt all my stuff is at home. Just expect the tuning frequency to move up a touch, and the reponse to be a little bit "peakier". But you should be just fine.
/NyxBass
markb
Member - Posts: 43
Posted: December 09, 2002 at 8:50 PM / IP Logged
thanks fellas, I'll post the results
-Mark
bberman1
Gold - Posts: 2,314
Posted: December 10, 2002 at 1:14 PM / IP Logged
Not a problem
