my speaker got some noise
Johnnynguyen20
Copper - Posts: 89
Posted: October 30, 2005 at 12:12 AM / IP Logged
hi, i have a 6x9 sony speaker. when i hook it in my 200 watts amp and it got some noise when i run on the engine. and very time i push on the gas pedal it get lounder. please help
Johnnynguyen
menace2sobriety
Silver - Posts: 394
Posted: October 30, 2005 at 12:23 AM / IP Logged
sound like a bad ground. or your speake wires are to close to your power wires.  check those two things and see if it helps.
dwarren
Posted: October 30, 2005 at 12:26 AM / IP Logged
Unfortunately amplified signal will not be affected by a power lead. However i suspect a ground issue here too.
menace2sobriety
Silver - Posts: 394
Posted: October 30, 2005 at 12:54 AM / IP Logged
okay. what about the rca cables being to close?
dwarren
Posted: October 30, 2005 at 1:17 AM / IP Logged
Read this link, then you can decide, maybe... https://www.the12volt.com/installbay/forum_posts.asp?tid=65069&PN=2
menace2sobriety
Silver - Posts: 394
Posted: October 30, 2005 at 1:32 AM / IP Logged
i will have to try this run them together.  it will save a little bit of tim to.
thanx dwarren
p.s. i hope you find the problem johnny
dwarren
Posted: October 30, 2005 at 1:35 AM / IP Logged
Not to bring up more issues, but there was never an agreement as to whether it did or not, my speaker got some noise -- posted image.
menace2sobriety
Silver - Posts: 394
Posted: October 30, 2005 at 1:49 AM / IP Logged
no issues ill try it and see what happens.  ill do it in my wifes carmy speaker got some noise -- posted image.
