Crossover Frequencies
kcirdnek
Member - Posts: 27
Posted: October 31, 2005 at 7:14 PM / IP Logged
I am looking for a crossover with the lowest frequency possible. What are the makes and model numbers of the crossovers with lowest frequency possible? I have a Coustic right now, and it goes down to 32Hz. Thanks for your help.
stevdart
Platinum - Posts: 5,816
Posted: October 31, 2005 at 7:24 PM / IP Logged
You can adjust almost any crossover to below human hearing, either by turning off a subsonic filter, running low pass or full-range instead of high pass, or removing a capacitor.  If there's nothing blocking or filtering the lows you'll get freqs as low as your music source is capable of playing.  What is it you're trying to do?  Are you looking for a subsonic filter and not a crossover?
menace2sobriety
Silver - Posts: 394
Posted: October 31, 2005 at 8:20 PM / IP Logged
these are in their specs
mtx lsx2 will go down to 20 hz.
ppi frx-456 will go down to 20 hz.
menace2sobriety
Silver - Posts: 394
Posted: November 02, 2005 at 4:51 AM / IP Logged
but stev is right!  your coustic at 35 HZ  its not soppose to let  any thing higher than 35hz pass what ever your disc or head unit. is  if  YOUR HU OR DISC  goes down to 10 hz then so will the x-over... in theory
DYohn
Platinum - Posts: 10,741
Posted: November 02, 2005 at 9:45 AM / IP Logged
What are you trying to accomplish?
kcirdnek
Member - Posts: 27
Posted: November 02, 2005 at 9:56 AM / IP Logged
Basically, I am doing a project on low frequencies. I just need a crossover with very low frequecies to accomplish this. That's all. Nothing special.
geepherder
Platinum - Posts: 3,668
Posted: November 02, 2005 at 8:22 PM / IP Logged
Most amps have built in crossovers, so as long as you set it to low pass, it will pretty much allow all frequencies below the crossover point to pass unharmed.  If it has a subsonic filter (blocks all frequencies below this point to protect the speakers being driven)  you'll need to turn it off.  That being said, your speaker system will need to be able to withstand the abuse you put it through.
I hope you're not trying to recreate the MythBusters experiment.
