howto seperate 50 and 70 RMS in same ch.
nikel
Member - Posts: 10
Posted: November 07, 2005 at 6:10 AM / IP Logged
hello
i have 2 components in my car 2 speakers front and two speakers in the back doors
front speakers are 70 RMS and back speakers are 50 RMS
they are connected in the same channel as 2 ohms
when i turn the music loud, back speakers make bad noises
what can i use to seperate them??? transistor? capacitor?
thank you for reading
stevdart
Platinum - Posts: 5,816
Posted: November 07, 2005 at 7:56 AM / IP Logged
You should have those separated already instead of paralleled together.  Right now you are trying to use more speakers than you have amplification for.  As soon as you can afford to, separate those pairs and put them on their own amplification at 4 ohms.  You'll then have controls, crossovers and gains to fine tune them individually, and the amplifier will be outputting at a higher quality into 4 ohm rather than into 2 ohm.
For a temporary fix now, you can put in high pass filters on those rear speakers to keep out some of the damaging bass freqs that is making them sound so bad.  See the help section on the left column... Passive crossovers, high pass filters, 4 ohm chart, 250uF non-polarized cap.  Solder the cap into the + wire as shown in the diagram.
geepherder
Platinum - Posts: 3,668
Posted: November 07, 2005 at 8:05 PM / IP Logged
Use your amp to power the fronts, and use your radio to power the rears.
nikel
Member - Posts: 10
Posted: November 08, 2005 at 3:00 PM / IP Logged
thank you very much for yuor valuable replies,
i wont forget this...
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
