95 Jeep w/ infinity problem
Benji999
Copper - Posts: 81
Posted: November 10, 2005 at 8:54 AM / IP Logged
We picked up a car here and it was missing the hu. It is in a 95 Jeep Grand Cherokee. All of the wires have been connected in accordance with the diagram provided on the site. There is no sound coming from the speakers though. The amp is still in and has both harnesses. The hu was tested and the audio outputs do work. Anyone know what the problem could be??
geepherder
Platinum - Posts: 3,668
Posted: November 14, 2005 at 7:33 AM / IP Logged
I'm assuming the GREEN/ red is not only the power antenna, but also the amp turn on.  Feed this 12 volts and see if you get sound.  If not, make sure the speakers are there, and check the fuses with a meter.  If that fails, bypass the amp, and make sure the speakers aren't all blown.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
