2004 mustang pop
bagedmazda
Member - Posts: 14
Posted: November 14, 2005 at 9:16 PM / IP Logged
2004 mustang W/mach factory
I built a new sub box and installed it today and also my front door speakers were sounding blowen so i bought a pair of pioneer 6x8 2 ways. It still has the factory mach head unit but now as your driving and you have the volume up you can hear a popping sound in the subs and mids and highs. Was thinking maybe my rca's. any info could help Thanks
geepherder
Platinum - Posts: 3,668
Posted: November 15, 2005 at 3:42 AM / IP Logged
I'm assuming you're using aftermarket amps to push your speakers.  If so, wire a 1.5k ohm resistor inline on the remote lead and call it good.  Ford uses a 5v turn on instead of 12v.
bagedmazda
Member - Posts: 14
Posted: November 15, 2005 at 9:14 AM / IP Logged
Yea i have a jl audio amp. also two i forgot to add also that when the volume is up it kinda sounds like ****. but if you fade it from front and back and side to side to just one speaker at a time its sounds alot better. Im puzzled by this install ive done a few and never had soo many problems.
Hornshockey
Silver - Posts: 520
Posted: November 15, 2005 at 12:50 PM / IP Logged
sounds like you have a speaker or two out of phase; check to make sure all the + and - terminals are hooked up the same on all speakers and subs.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Hornshockey
Silver - Posts: 520
Posted: November 15, 2005 at 12:52 PM / IP Logged
oh and geepherder
wouldn't that resistor only apply in the reverse situation, i.e. an aftermaket HU with the factory amps?
bagedmazda
Member - Posts: 14
Posted: November 15, 2005 at 3:39 PM / IP Logged
well im thinking that the stock system is a 8 ohm and i just threw in some 4 ohm front 6x8. maybe
geepherder
Posted: November 15, 2005 at 9:01 PM / IP Logged
Yeah, your absolutely right Hornshockey, what was I thinking- oh yeah, I wasn't.
It wouldn't matter if your speakers are 4 ohm, as long as your JL is pushing them, and not the factory amps.  If you're getting a popping sound in the speakers and sub, I'd check the gain adjustments.  But keep in mind that many Ford systems usually start distorting around 1/2 volume, sometimes even sooner.  That being said, consider the deck may be your weak link- garbage in, garbage out.
extcab96_sdime
Posted: December 06, 2005 at 1:18 AM / IP Logged
I just installed a new deck into a 1996 Mustang with the Mach system and everytime you start the car it makes a popping noise.  Would this be the instance where I would have to, as geepherder previously said, wire in the 1.5k ohm resistor?
geepherder
Posted: December 06, 2005 at 5:58 PM / IP Logged
Yes- if you didn't bypass the Mach amps, use the resistor and you'll be good.
extcab96_sdime
Posted: January 06, 2006 at 3:55 AM / IP Logged
I tried putting the resistor in and it still pops when starting it.  Is there any other reason?
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
