why is stereo cutting off
huzilbyjx
Posted: November 19, 2005 at 12:50 AM / IP Logged
i bought one "75 kingswood holden" australian made old car. tried to install a new stere system. jvc with mp3. installed according to the installation guide. the sounds just cuts off when volume up and back on again. do you guys know what is going on? thanks
huzilbyjx
Posted: November 19, 2005 at 12:51 AM / IP Logged
any chart to show how to wire it if another wiring method is needed? thank you very much
menace2sobriety
Silver - Posts: 394
Posted: November 19, 2005 at 1:07 AM / IP Logged
bad ground or a very small power wire could cause that.
raisedfist
Member - Posts: 9
Posted: November 19, 2005 at 11:48 PM / IP Logged
is there any amp involved in this?
might be your gains if there is, thats what happened to me...
but if it is just your head unit, it probably is the ground of the power cable... maybe your battery is on its way out..
huzilbyjx
Posted: November 20, 2005 at 10:28 PM / IP Logged
there was no amp.
11v-16v is the normal working condition, but i tested it when it cuts the volts is a little below 11v, do you this caused the problem?
i tried to attach the ground to the body, and other locations, the same thing happened.
please help
thanks.
menace2sobriety
Silver - Posts: 394
Posted: November 21, 2005 at 2:22 AM / IP Logged
under 11 volts that sounds like your problem. with volume down it plays fine. but up it cuts out makes sence.  is that with the car running? or off? if its when your car is running then you have a charging problem. off sounds like a weak battery.
jlord16
Silver - Posts: 322
Posted: November 21, 2005 at 2:37 AM / IP Logged
The batteries proberly been in there for ages, or isnt designed for that vehicle.  Under 11 volts isnt a good thing.  Sounds like at higher levels there isnt enough charge to run the head deck
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
raisedfist
Member - Posts: 9
Posted: November 21, 2005 at 3:49 AM / IP Logged
i agree...
best to get your abtt tested to make sure...
i think thats the prob
huzilbyjx
Posted: November 21, 2005 at 5:04 AM / IP Logged
it happens all the time, with the car runing is a little bit better, but still cuts.
i tested the battery with the car runing about 14.6v without  12v, and i just had my alternator and start motor changed over.
i asked the staff at highpoint jb hi-fi, he said cuting off because the headunit will protect itself from overheating and "common ground" can solve this problem. but it happens even the headunit is cold.
( they charge me $50 to do the common ground for me, but i want to do it myself, is there anyone can link me a diagram , thanks)
thanks
please help againwhy is stereo cutting off -- posted image.
menace2sobriety
Silver - Posts: 394
Posted: November 21, 2005 at 12:32 PM / IP Logged
check the ground wires from the batt to the chassis. and from the motor to the chassis. theres your common ground.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
