Finding Speaker Resistance
coppellstereo
Silver - Posts: 785
Posted: December 03, 2005 at 3:55 PM / IP Logged
I tried searching, but must not be using the right queries.
How do you use a multi-meter to measure speaker impendence?
Thanks!
coppellstereo
Silver - Posts: 785
Posted: December 03, 2005 at 3:57 PM / IP Logged
impedance*
forbidden
Platinum - Posts: 5,354
Posted: December 03, 2005 at 4:31 PM / IP Logged
Set the speakers to read ohms, take one probe and touch it to one speaker terminal, take the other probe and touch it to the other terminal.
bdl666
Silver - Posts: 330
Posted: December 03, 2005 at 4:35 PM / IP Logged
I want one of those!
forbidden
Posted: December 03, 2005 at 4:37 PM / IP Logged
Make that set the meter to read ohms......nice one Rob, teaches you to talk on the phone at the same time.
DYohn
Platinum - Posts: 10,741
Posted: December 03, 2005 at 4:58 PM / IP Logged
And realize that the above will get you the DC resistance of the speaker, not the impedance.  Impedance is dependent on frequency and changes continuously.  DCR is always different from impedance, most times lower than rated impedance, but sometime higher.  It depends on the speaker.
coppellstereo
Silver - Posts: 785
Posted: December 03, 2005 at 5:24 PM / IP Logged
My meter just jumps to infinity, like the circuit is complete.  Am I doing something wrong?
dwarren
Posted: December 03, 2005 at 5:33 PM / IP Logged
Perhaps they are blown. Why are you testing them to begin with?
Where is meter set on the ohm range?
coppellstereo
Silver - Posts: 785
Posted: December 03, 2005 at 5:35 PM / IP Logged
definitely not blown.  Maybe I dont know how to adjust my ohmeter.  All I see for adjustment is the needle itself and the red dial on the side.  Ill try playing with that
geepherder
Platinum - Posts: 3,668
Posted: December 03, 2005 at 7:03 PM / IP Logged
Hahaha.  Rob, that's hilarious.  I didn't even catch that typo until I read the next post.
Are you trying to test for speaker leads behind a radio, or are you testing speakers themselves?  If you're testing wires, chances are you may have a factory amp, and need to test there.  You said the speakers are definitely not blown- how do you know?  Did you hook them up, and get sound?  If you're testing the speakers themselves, set the meter on a scale that can easily measure 4 ohms.
It sounds like your using an old volt-ohm meter.  I suggest picking up a digital multimeter instead because it's safer.  That being said, if you must use an analog meter, here's how: Be sure the probes are inserted in the right slots on your meter- black to common, or ground, and red to ohms (not amps).  Set the meter on a resistance scale proper to measure around 4 ohms.  Now short the two probes together and calibrate to zero.  You should be ready for testing.
The analog volt-ohm meters are usually only useful if you're watching for voltage fluctuations- the needle can respond quicker than a digital readout.  Other than that, they should not be used to test wires in newer cars because, like test lights, they do not offer a high resistance, and could cause damage to sensitive electronics (set off air bags, etc.).
