Sony Xplod Amplifier
bumpsy5250
Member - Posts: 9
Posted: December 13, 2005 at 12:01 PM / IP Logged
My sony Xplod will not play because of an overcurrent protection light. Any idea what causes overcurrent fault? The voltage is fine, around 12.70 with vehicle off and 13.98 with vehicle running. I appreciate any help, Thanks.
Bumpsy
coppellstereo
Silver - Posts: 785
Posted: December 13, 2005 at 12:09 PM / IP Logged
Line level or RCA input?
Poormanq45
Silver - Posts: 597
Posted: December 13, 2005 at 12:20 PM / IP Logged
Huh, 12.7 when the vehicle is off?
bumpsy5250
Member - Posts: 9
Posted: December 13, 2005 at 1:03 PM / IP Logged
I am running rca inputs and yeah, around 12.7v or so when off. Its in a 94 Nissan Max if that helps any. I've never had any problems before though. Had the amp installed for roughly 3 years now.
Bumpsy
geepherder
Platinum - Posts: 3,668
Posted: December 13, 2005 at 7:25 PM / IP Logged
Disconnect the speaker wires from the amp and see if the light goes off- if it does, your problem lies in the speakers and/or wiring.  If it doesn't, you've got a bad amp.  You can either have it repaired, or replace it.
bumpsy5250
Member - Posts: 9
Posted: December 14, 2005 at 6:23 AM / IP Logged
I only one 10" sub on it and I disconnected it. The light was still on unfortunately.
Bumpsy
haemphyst
Platinum - Posts: 5,059
Posted: December 14, 2005 at 7:27 AM / IP Logged
Sounds like the amp is fried. COMPLETELY disconnect all wires from the amp, and see if that resets it. If not, looks like you are sending it back to Sony for repair, or dropping some bennies on a new one...
bumpsy5250
Member - Posts: 9
Posted: December 14, 2005 at 7:31 AM / IP Logged
I'll try removing all the wires
Bumpsy
mariocesar
Member - Posts: 48
Posted: December 14, 2005 at 4:48 PM / IP Logged
´what are the specs of the amp and the sub?
Maybe you fried the amp
alpine_king
Copper - Posts: 73
Posted: December 14, 2005 at 6:20 PM / IP Logged
well since it was a sony, you could've fried it very easily, sony amps are known to get really hot.  I had a sony amp before and it would get so hot you could prolly light a cigarette off of itSony Xplod Amplifier -- posted image. haha. never tried tho.
1993 Ford Ranger.
Head Unit.Alpine CDA-9831
Front Speakers.Infinity 6010 Reference Series
Amp.Alpine MRD-M1005
Subs.3 Kicker CVR10
Rear Speakers.SPL CS-573
20" Boss 312's, lowered 3/4
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
