Strange Mitsubishi Eclipse stuff
tym1200
Member - Posts: 13
Posted: December 29, 2005 at 4:22 AM / IP Logged
Ok heres the deal, I have a 97 Eclipse RS that came with the regular stereo system, not the Infinity one. My stock reciever was stolen, and I picked up the factory radio from my friends 95 GSX that came with the nice Infinity system. I know that the new radio uses an external amp but I do not have one. How would I hook up an aftermarket amplifer to the stock radio? And do you think there would be any other wiring problems? I've installed and it and turns on and everything, there is just no sound!
tym1200
Member - Posts: 13
Posted: December 29, 2005 at 4:27 AM / IP Logged
Would this work by any chance ??
http://www.installer.com/cars/mitsubishi.html   .... the Direct plug in adapter to replace factory head unit or amp.
one of our most popular parts of all time."
stevdart
Platinum - Posts: 5,816
Posted: December 29, 2005 at 8:08 AM / IP Logged
Buy an aftermarket amplifier which will directly power the speakers.  For signal input to the amp, use a high quality line output converter (LOC).  You can find one HERE.
geepherder
Platinum - Posts: 3,668
Posted: December 29, 2005 at 5:33 PM / IP Logged
Yes, that looks like that will work.  You'll plug the DIN cable into the factory radio, and run RCA's to your new amp.
Steve- that won't work- he's using the Infinity system headunit without the factory amp, so he only has low level signal anyway.
