Adding antenna/power wiring
lylesgold
Posted: December 31, 2005 at 3:14 PM / IP Logged
New to this but handy, I'm hoping someone can direct me to some basic instruction on how to run a wire inconspicuously from an outside antenna (sat radio) to the dash, is there a tool to lift the rubber seal around a window etc for the insertion of a wire, how to waterproof same, how to get wire behind panels etc, penetrating fire wall if necessary, that sort of thing. Could not find this already posted.
Thanks,
Lyle
the Installater
Member - Posts: 19
Posted: January 01, 2006 at 1:12 AM / IP Logged
everytime i run the antenna i usally run the wire under teh seal with a credit card or something like that. if you cant do it in the front on the roof then run it from the back on the trunk.. and if you have a truck or suv then run it from the third brake light.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
