Tiny surround puncture fix?
spootydlux4
Copper - Posts: 149
Posted: January 01, 2006 at 5:48 PM / IP Logged
Ok i was screwing in the last screw to finish up my component install, and of course my screwdriver slipped and put a tiny puncture about the size of  this [ ] in the surround and put a dent in the cone about the same size. I'm still pissed. Is there anything i can put on this to fix it, maybe rubber cement or silicone?
blah blah blah blah
youngone
Silver - Posts: 269
Posted: January 01, 2006 at 6:45 PM / IP Logged
use the rubber cement it'll do the trick.
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
mtxthunder9500
Posted: January 01, 2006 at 9:41 PM / IP Logged
i have used this glue called E 6000 it work awesome even in cold temps and warm temps
nolte audio checkem out
2 mtx 9500 12's in a nolte audio double signature box...need an amp 3000 watts at 1 ohm?
spootydlux4
Copper - Posts: 149
Posted: January 01, 2006 at 10:11 PM / IP Logged
where did you get it?
blah blah blah blah
mtxthunder9500
Posted: January 01, 2006 at 10:40 PM / IP Logged
at any craft store you can find it. I got it at a craft store in the area where i live called michaels. It comes in a grey or silver tube. I swear by it is some awesome stuff its very plyable and is able to bend. Here is a link for the place i got it at http://www.michaels.com/art/online/search?pageNumber=1&channel=0&search=yes&keywords=e+6000&type=0&x=10&y=6
kirktcashalini
Silver - Posts: 492
Posted: January 02, 2006 at 12:31 PM / IP Logged
HAH we did this on one of my friends setups. fortunatly he bought the 2 year replacement warrantee or something. but what you need to do is get one of those drivers for your drill that has the slide cover, so you can load the screw, then slide the slide piece down, then you are 100% ensured that you wont slip and slide the bit into the speaker. Get one, its a big time insurance at little cost.
did a quick search, something liek the middle piece there, with the slide cover or something. I will never install a speaker without one.
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&fromAuto=YES&bidsite=CRAFT&pid=00925599000
godblessdremil
Silver - Posts: 273
Posted: January 02, 2006 at 12:38 PM / IP Logged
Thats why i always put a peace of cardboard over the speaker when ii screw shhh in. Especally When i am using a drill to get a screw into metal. As for above shoud work.
spootydlux4
Copper - Posts: 149
Posted: January 03, 2006 at 5:12 PM / IP Logged
thanks very much guys, ill post an update whenever i get time to fix it
blah blah blah blah
