Posted: January 04, 2006 at 4:02 PM / IP Logged
Posted: January 04, 2006 at 4:35 PM / IP Logged
Posted: January 04, 2006 at 5:12 PM / IP Logged
Posted: January 04, 2006 at 6:15 PM / IP Logged
Posted: January 04, 2006 at 11:37 PM / IP Logged
Posted: January 05, 2006 at 12:48 AM / IP Logged
Posted: January 22, 2006 at 4:10 PM / IP Logged
Posted: January 22, 2006 at 11:12 PM / IP Logged
Posted: January 23, 2006 at 1:13 AM / IP Logged
Posted: January 23, 2006 at 6:35 AM / IP Logged
Friday, March 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
http://static.flickr.com/37/82201703_d0ab65ab80.jpg?v=0
The walls are 20mm thick dense PVC plastic
Woked out from the internal diameter, to get the required 28.3 liters, (Enclosed), I would need 480mm of pipe + 20 mm for the MDF end cap.I used maskin tape to get a dead streight line at both ends
Then cut the pipe with a wood saw, this took the best part of an hour, its like cutting hardwoodHere it is cut capped and sealed with silicone
Then cut and fitted the carpet, wired and assembled.
The Finished product
This is my first attempt at a Sub enclosure, I think it looks prety Stock. It certainly beats my tempory Sub in a plastic bucket solution.
The frequency response is much flatter (I can tell because i dont have to change the balance every time a new track comes on) and the Bass is a lot less boomy.thanks to those who have advised over the last couple of weeks.
