What Brand?
playaa
Member - Posts: 13
Posted: December 23, 2002 at 12:45 AM / IP Logged
I got a single cab 1995 chevrolet s-10, I plan on putting  2 10"s or 2 12"s behind the seats in sealed enclosures, I want to run 5.25" Components in Q-form kickpanels, and 6.5" Midbass drivers in the stock door locations..   I want to run 1 amp for subs, 1 amp for component, and 1 amp for midbass's. I want a 2 farad cap on all 3 amps.
What is the best brand to go with for an SQ setup out of these... Visonik, MA Audio, Digital Audio, Audiobahn, Ultimate, Power Acoustik?
Also for the sub-box spec's it needs to be sealed and no bigger then
5/8" MDF Construction
15.25"H x 14.75"W x 4.25"TD x 7.75"BD
bberman1
Gold - Posts: 2,314
Posted: December 23, 2002 at 9:26 AM / IP Logged
How much are you looking to spend?
playaa
Member - Posts: 13
Posted: December 23, 2002 at 9:34 AM / IP Logged
doesnt matter
playaa
Member - Posts: 13
Posted: December 23, 2002 at 9:35 AM / IP Logged
got around 2,000 saved up in bank plus going to get most of this for christmas presents
playaa
Member - Posts: 13
Posted: December 23, 2002 at 9:37 AM / IP Logged
I am really looking to get this type of setup...
1995 Single Cab S-10
5 1/4" 3-way Component Set
2-Channel Amp
Q-Logic KickPanels
6.5" MidBass Drivers
2-Channel Amp
2 10" Subwoofers
Mono Amp
Truck Boxes
playaa
Member - Posts: 13
Posted: December 23, 2002 at 9:40 AM / IP Logged
Also I am looking to go with all 1 brand and im kinda partial to sticking with these brands if possible
Audiobahn, MA Audio, Visonik, Digital Audio, Power Acoustik, Ultimate Sound, JBL... Because I am wanting to spread my money out and get the video and security perspective also.
bberman1
Gold - Posts: 2,314
Posted: December 23, 2002 at 4:21 PM / IP Logged
For your mids and highs I would look at the MB Quart Q series http://www.mbquart.com/listings.asp?cat=Auto&strt=1&series=Q+Series and to power them the Audiobahn A4125HCQ http://www.audiobahninc.com/products/results.asp?categoryID=9&seriesID=21&offset=5#  the amp puts out some serious clean power and the sound is very clear and crisp.
As far as the subs go I would suggest 3 Audiobahn Alum10’s http://www.audiobahninc.com/products/results.asp?categoryID=5&seriesID=34# and to power them a Audiobahn A18001DQ. http://www.audiobahninc.com/products/results.asp?categoryID=9&seriesID=24#
Or a A2300HCQ http://www.audiobahninc.com/products/results.asp?categoryID=9&seriesID=21#
This is just one suggestion. If I were you I would go to your local shops and listen to all the different brands. Then make your decision on what sounds best to you. However I would not suggest Audiobahn for your mids and highs
