how to wire two kicker s8l7's?
b20god
Member - Posts: 9
Posted: January 10, 2006 at 8:02 PM / IP Logged
ok so her is what ive got goin on ive got two kicker s8l7's behind the seats of my regular cab 1999 s-10 right now its wired to a pioneer 1000 watt class D single channel amp
they are wired like this at the moment
how to wire two kicker s8l7's? -- posted image.
ive got them wired just liek together well i mena i just put both the grounds from both subs, and the positives from both subs and just wired them strait to the amp. theres only one spot on the amp thats like spekaer out, so i plugged both subs into the same spot.. is this bad or is it alright? is there a differant way i should have these subs wired?
geepherder
Platinum - Posts: 3,668
Posted: January 10, 2006 at 9:18 PM / IP Logged
I believe those are dual 4-ohm voice coil subs, which when wired in parallel  creates a 2 ohm load each, or a 1 ohm load all together.  I'm not so sure you're amp is stable to 1 ohm or not (check your manual).  Most mono amps are stable to 2 ohms, but not necessarilly 1, so check to be certain.
If your amp is not stable to 1 ohm, you can series the voice coils, and parallel the woofers, creating a 4 ohm load.  Otherwise, get rid of one woofer and just parallel the voice coils for a 2 ohm load.
b20god
Member - Posts: 9
Posted: January 10, 2006 at 9:25 PM / IP Logged
alright well one question... wahts the differance in wiring the woofer or the voice coil? like yea i dont know what yer talkin about there
youngone
Silver - Posts: 269
Posted: January 10, 2006 at 9:42 PM / IP Logged
the woofer is the speaker as a hole the voice coil is the part that is inside the magnet. you are wireing the voice coil by hooking the wires to. im gessing you are new to this stuff.so gust look at the woofer wireing link in the left hand side of the page. it will show you a number of ways you can wire your subs go for 4ohms. gust mess around with it.
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
b20god
Member - Posts: 9
Posted: January 10, 2006 at 9:50 PM / IP Logged
alright well i changed the wiring to i think a 4ohm load.. well this is how its wired now
or well liek this
i guess i cant really tell if it sounds any differant or not.. is this  how u think i should have it wired or not?
geepherder
Posted: January 10, 2006 at 10:33 PM / IP Logged
Yes, that's what we mean.  Your subs are actually dual 4 ohm voice coils, not 2 ohm, so you're amp is running at 4 ohms.
speedwayaudio1
Silver - Posts: 879
Posted: January 10, 2006 at 11:49 PM / IP Logged
here you go.
Big Dave
b20god
Member - Posts: 9
Posted: January 11, 2006 at 3:41 PM / IP Logged
alright yea thats how ive got it wired... is that good or no?
TruckSystem
Copper - Posts: 185
Posted: January 11, 2006 at 4:10 PM / IP Logged
That is how I would leave it, running at one ohm tends to make things run very hot and more susceptible to problems.
2003 Chevrolet Silverado Standard Cab ~ Alpine CDA-9851
Diamond Audio D3600.1 ~ 2x Diamond Audio TM310D4
Diamond Audio D3400.4 ~ Diamond Audio Hex S600s
AstroStart RS5204 Remote Start/Alarm
b20god
Member - Posts: 9
Posted: January 11, 2006 at 4:27 PM / IP Logged
alright thanks
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
