Best way to power Neons
coppellstereo
Silver - Posts: 785
Posted: January 13, 2006 at 11:15 PM / IP Logged
I am only running on set of 2 cold cathode tubes.  Can i tap into the amps power?  I really dont want to run a new set of power wire for these lights.
coppellstereo
Silver - Posts: 785
Posted: January 13, 2006 at 11:16 PM / IP Logged
it is for my girlfriend's 2001 honda civic.  any 12v+ in the trunk i could tap into?
kirktcashalini
Silver - Posts: 492
Posted: January 13, 2006 at 11:36 PM / IP Logged
lolwhat your girlfriend need a neon trunk for? well. they dont draw much power it probably would be fine it you just tapped into the amp power wires, what gauge are they?
coppellstereo
Silver - Posts: 785
Posted: January 14, 2006 at 12:37 AM / IP Logged
running 4 gauge to the sub, i guess the easiest way is how i have it - screwed in with the power wire into the amp.
any other easy fixes?
it is the jbl gto series amp, you can put neon's inside it, pretty slick - remember the pics i showed you?
coppellstereo
Silver - Posts: 785
Posted: January 14, 2006 at 1:51 AM / IP Logged
could i use a ground distribution block to split the power cable, and connect the lights there to make the actual amp wiring look better?
geepherder
Platinum - Posts: 3,668
Posted: January 14, 2006 at 9:20 AM / IP Logged
Yes, you can use amp power.  You can use the trunk light wires to activate a relay, that way the neons come on whenever the trunk is opened.
