Wiring a JL w7
cdub74
Member - Posts: 21
Posted: February 04, 2006 at 3:45 PM / IP Logged
Here's what I have: one (soon to be two) jl 12 w7 and an old school us amps 400x.
Amp specs are: 400 x 2 @ 4ohms or 750 x 2 @2 ohms or 1500 x 1 @ 2ohms (under rated, but anyway)
The jl is a single v.c. @ 3 ohms, so what is my best wiring configuration for now (1 speaker) and later (2 speakers)
DYohn
Platinum - Posts: 10,741
Posted: February 04, 2006 at 3:59 PM / IP Logged
Well as it is a SVC speaker, there is only one wiring configuration possible.  As far as connecting to that amp, you may be in trouble as a US Amps 400X is only rated to 4-ohms when bridged.  It will probably handle a 3-ohm load, so I'd try that.  Bridge the amp with the one speaker and see if it remains stable.  When you get two speakers, you'll have to wire them in series for a 6-ohm load.
i don't know where you got the specs you list.  According to the manufacturer, that amp is rated as follows:
  • 100 Watts x 2 into 4 Ohms
  • 132 Watts x 2 into 3 Ohms
  • 200 Watts x 2 into 2 Ohms
  • 400 Watts Bridged into 4 Ohms
  • You may want to look into a different amp.
    cdub74
    Member - Posts: 21
    Posted: February 04, 2006 at 4:07 PM / IP Logged
    The amp your looking at is the new one. The specs I listed are correct and can be found at the old us amps site. Goto the old site and click on online documentation at the bottom then under white papers you will find it.
    cdub74
    Member - Posts: 21
    Posted: February 04, 2006 at 4:09 PM / IP Logged
    I should also say that I have ran this amp @ 1ohm for  a few weeks and had no problems.
    cdub74
    Member - Posts: 21
    Posted: February 04, 2006 at 4:11 PM / IP Logged
    1500 watts @ 4ohms, my mistake
    DYohn
    Posted: February 04, 2006 at 4:15 PM / IP Logged
    Then it seems you have your answer.  Cheers.
    cdub74
    Member - Posts: 21
    Posted: February 04, 2006 at 4:22 PM / IP Logged
    So how do I wire two of them?
    stevdart
    Platinum - Posts: 5,816
    Posted: February 04, 2006 at 5:19 PM / IP Logged
    You've already answered your own question.  Didn't you say above that you ran this amp at 1 ohm with no problem?  1.5 ohms is a lighter load, so....
    You know there is a wiring configurarion application in the left column, right?  1.5 ohms or 6 ohms, take your pick.
    cdub74
    Member - Posts: 21
    Posted: February 05, 2006 at 2:19 PM / IP Logged
    Thanks for the help!
