Resistor ?
Brianas
Copper - Posts: 50
Posted: February 13, 2006 at 3:18 PM / IP Logged
what resistor would I use to get a 12volt signal down to 5-6 volt
for factory amp turn on lead-- so very low current
thanks
Josh
Mad Scientists
Silver - Posts: 380
Posted: February 13, 2006 at 3:24 PM / IP Logged
You have to know the current to be able to figure the resistor size.. if you need a 7 volt drop, and you have 0.010 amps of current, you would use a 700 ohm resistor.
Ohms Law
Voltage equals amps times resistance
7 volts equals 0.01 amps times 700 ohms.
Jim
geepherder
Platinum - Posts: 3,668
Posted: February 13, 2006 at 7:00 PM / IP Logged
For a factory Ford system, use a 1.5k ohm resistor inline on the turn on lead, and call it good.
haemphyst
Platinum - Posts: 5,059
Posted: February 13, 2006 at 9:41 PM / IP Logged
The preferred method would be a 7905 three terminal voltage regulator. Good for 500mA without heatsink, or 1A with heatsink. Simple wiring too... no math. Input (9 to 37VDC), ground terminal, and 5V fixed output. Cheaper than an adequately powered resistor would be too.
Brianas
Copper - Posts: 50
Posted: February 15, 2006 at 9:10 AM / IP Logged
thanks for the replys
the resistor method did not work for some reason
but I also got a 7805 5v reg. could not find the 7905
and this works excellent-- cost $1.59  took 5 min. to solder\heat shrink
it must have the middle pin grounded though--not a big deal
thanks again
Josh
JB Customs
haemphyst
Posted: February 15, 2006 at 10:13 AM / IP Logged
Actually, I am glad you couldn't find the 7905... That's the NEGATIVE 5v voltage regulator. Typos of this sort can be bad... The 7805 IS the number you wanted, and I am glad it all worked out for you!
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
