jeep liberty speakers
hexnut
Member - Posts: 21
Posted: February 22, 2006 at 7:56 PM / IP Logged
Just looking for some advice on what to look for when buying speakers?I need 4 speakers for my jeep liberty?Any good suggestions would be appreciated.
forbidden
Platinum - Posts: 5,354
Posted: February 22, 2006 at 8:41 PM / IP Logged
You will need to make mounting adaptors for this vehicle. Once done you can easily fit 6.75" coax speakers all the way around or use components up front. If you are not going to be using a amplifier on them, keep it to some good coax (2way) type speakers like Focal or MB Quart. If you are going to throw an amp into the mix, definitely do the component speakers up front. The doors of this vehicle ring like you would not believe, knock on it and you will hear what I mean, add some Brown Bread to these doors and tonal response will improve even more.
Teamrf
Gold - Posts: 1,031
Posted: February 22, 2006 at 11:02 PM / IP Logged
Build the rings...don't just slap some duct tape or something back there so it "fits"
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Ravendarat
Platinum - Posts: 2,806
Posted: February 22, 2006 at 11:12 PM / IP Logged
Respect the duct tape solution
tcss
Silver - Posts: 1,623
Posted: February 23, 2006 at 11:45 AM / IP Logged
This truck has factory components. Woofer in the door, tweeter in the dash. If you are going to use coax measure the impedience of the front speakers at the back of the radio. Make sure the ohm rating is not less then 4. If it is pull and disconnect the stock tweeters or the deck will shut down.
There is no such thing as free installation!
Ravendarat
Posted: February 23, 2006 at 11:47 AM / IP Logged
I can say from experience that you can put coax in the front with the factory tweeters still connected and there will be no issues running said setup off a deck. I have done more than one of these vehicles this was with no issues.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
