constant power, 86 pontiac grand prix
robertoa81
Posted: March 12, 2006 at 1:14 PM / IP Logged
I got a 86 pontiac gp that had a really really ridiculously old AM only radio in it. I for the life of me cannot find the constant power wire. I've identified the switched wire just fine but Im begining to suspect that there may not be an exsisting constant power wire going to the old stock harness. Any feed back or suggestions would be greatly appreciated.
boulderguy
Silver - Posts: 510
Posted: March 12, 2006 at 1:16 PM / IP Logged
The constant wire is generally only for memory.  I suspect yours doesn't have one.
robertoa81
Posted: March 12, 2006 at 1:19 PM / IP Logged
 Right, but im trying to put in a newer head unit that requires constant power. Sorry I should have mentioned that before.
boulderguy
Silver - Posts: 510
Posted: March 12, 2006 at 1:24 PM / IP Logged
Which means you'll probably have to find a new constant at the fusebox.
robertoa81
Posted: March 12, 2006 at 1:26 PM / IP Logged
 OK well I think the biggest problem right now is that im a newb. So perhaps you can give me some more detailed instructions
boulderguy
Silver - Posts: 510
Posted: March 12, 2006 at 1:51 PM / IP Logged
Get yourself a test light & check the cig lighter for constant power.  Or a multi-tester & find a wire behind the fusebox that's constant.  Tap in & run to new headunit.  Be sure to verify that the constant power needs of the new HU are very low, like less than 1 amp.  If larger then you have a different problem.
geepherder
Platinum - Posts: 3,668
Posted: March 12, 2006 at 7:09 PM / IP Logged
At the ignition harness under the dash, you will have a thick red wire.  This is constant power.  Connect a fuse holder to this and run a wire from this to your deck.  Use a 5 to 10 amp fuse.  It's always wise to test all wires with a multimeter for proper function.  You can pick up a simple one at RadioShack for around $20.
robertoa81
Posted: March 12, 2006 at 8:09 PM / IP Logged
Thanks guys I'll try it out and post my results. Thanks!
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
