XM to Sirius Converter
bigolyt
Posted: March 16, 2006 at 11:34 AM / IP Logged
I hope this is the right area....
I just got a 06 GMC Sierra Denali. Comes with XM, but I previously have a SIRIUS Sub. Anyone know of anything that will allow me to use the factory unit along with the antenna that was installed to work with my Sirius??
doibuy
Copper - Posts: 177
Posted: March 16, 2006 at 11:40 AM / IP Logged
Soundgate makes an interface for GM vehicles, I think that it  requires a Kenwood tuner.  As for using the factory antenna, the XM tuner box is behind the glove box. You may have to remove the Yellow outer plug to hook up with the Sirius.
bigolyt
Posted: March 16, 2006 at 11:42 AM / IP Logged
I called soundgate, they said I have to run a new antenna... ive seen the Sirius Connector. Back ordered for a while, but its a tuner box basically.... Im looking for something EASY  :)
xscash
Copper - Posts: 317
Posted: March 16, 2006 at 11:49 AM / IP Logged
you want easy or right? doibuy told you the right way...if you want easy ....get a s50 from sirius and fm modd it .
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
