Power but no sound
cgkmark
Member - Posts: 25
Posted: March 29, 2006 at 11:10 PM / IP Logged
Hey there...just took my dash apart to paint and when i went to put everything back i plugged my stereo in and tried it out...i had power...but no sound...and the amp had power so the subs worked and a beat came out but i had nothing come from the other speakers...as far as i no none of the wiring was moved around enough to unplug all of the wires? Is there a reset switch on the deck or something?
DYohn
Platinum - Posts: 10,741
Posted: March 30, 2006 at 12:30 AM / IP Logged
Did you disconnect the battery before you "took the dash apart"?  Sounds like a fuse is blown.  Or yes you have disconnected something.
