Connectiong headunit to three amps
jdiablo
Member - Posts: 25
Posted: April 15, 2006 at 8:05 PM / IP Logged
In my old focus I was running just one 12 inch sub,and I hooked up the RCA wires to the back of the HU and then just ran it to the amp.Now my ? is,Im getting a new car and I plan on running three subs and three amps,how do I hook up the Rca to each amp.Do I run the RCA from the HU to one amp,and then just connect each amp toghter with the other RCA plug outlets?
jkpa45
Posted: April 15, 2006 at 8:17 PM / IP Logged
get a crossover
jdiablo
Member - Posts: 25
Posted: April 15, 2006 at 8:28 PM / IP Logged
One of these you mean?
[IMG]https://i32.photobucket.com/albums/d19/john3030/KIC03KX3_1.jpg[/IMG]
jdiablo
Member - Posts: 25
Posted: April 15, 2006 at 8:29 PM / IP Logged
Connectiong headunit to three amps -- posted image.
jkpa45
Posted: April 15, 2006 at 8:32 PM / IP Logged
yes, if you have one that has three outputs, that feed from one imput, there are some rca splitters out there, or if you are using a stock headunit, you could use three hi/low converters
jdiablo
Member - Posts: 25
Posted: April 15, 2006 at 8:38 PM / IP Logged
Will I be able to use this one and just not use the one extra RCA plug?
Ravendarat
Platinum - Posts: 2,806
Posted: April 15, 2006 at 10:01 PM / IP Logged
What kinda amps are they. Many amps have rca in and out, if they do then you can daisy chain them all together.
jdiablo
Member - Posts: 25
Posted: April 15, 2006 at 10:22 PM / IP Logged
They are phoenix gold 1600watt 4 channel pd-396,I would rather have the clean look though because the amps are going to be exposed
Ravendarat
Posted: April 15, 2006 at 11:44 PM / IP Logged
You can still use the ins and outs to have a clean look provided you know how to run wires properly.
jdiablo
Member - Posts: 25
Posted: April 16, 2006 at 3:27 PM / IP Logged
Yes I do for the most part,I will just buy that four channel RCA cable,thanks for the replies guys.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
