Radio problem
ronlu58@sbcglob
Posted: April 27, 2006 at 1:21 PM / IP Logged
I have a hidden audio radio installed along with an automatic antenna.  If you turn the ignition switch to "run" or "accessory" the antenna will extend and the radio will come on.  Everything on the radio seems to function correctly. you can see the unit seeking stations and locking on.  However, there is no audio through the speakers.  No popping, hissing, nothing at all.
But with the unit on, if you disconnect the radio lead male plug, from the speaker female plug..then plug it back together..the unit works fine and everything functions as it should.
If you shut off the ignition, and the antenna fully retracts, the radio returns to original and no longer has audio.  But, if you shut off the ignition, and then turn it quickly back on, before the antenna fully retracts it keeps playing fine.
I have noticed that should you disconnect the antenna "trigger" wire from the radio, it immediately goes dead again.
I thought it was a ground problem, but what could possibly be making that speaker plug, sort of function as an on off switch?
Ronlu
kgerry
Platinum - Posts: 3,455
Posted: April 27, 2006 at 5:27 PM / IP Logged
i have seen units with a bum output IC do this exact thing... the IC gets overdriven into a standby mode when turned on, but when you take the IC "no-load" it clears itself and when the speaker wire is reconnected the unit works fine....   but the problem re-occurs when the unit is powered down and then re-powered up.....
that could be the problem you are having with this unit... the solution is usually to replace the output stage....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
ronlu58@sbcglob
Posted: April 27, 2006 at 10:01 PM / IP Logged
Thanks Kevin.  I'll contact the manufacturer since they are a in the Los Angeles area, and are reasonably near me.  The unit is brand new so I will see if they will accept it for return for replacement or repair.  Anyone else have any ideas what the problem might be?
Ronlu
ronlu58@sbcglob
Posted: May 24, 2006 at 11:15 AM / IP Logged
Well, I returned the radio to Custom Autosounds for testing, and they returned it stating that it tested correctly and that everything was fine.  I reinstalled the radio and the same condition exists.  The unit will perform all functions on the separate control head, BUT, no sound.  If you disconnect the speaker lead and reconnect, it will play.  I have checked all power leads coming into the the unit and that's all fine.  I have completely disconnected the antenna and it still will not work without the plug/unplug being done.
BUT..something new has been added.  When you turn the ignition to either accessory or run the radio will play (providing you plug/unplug the speakers), but if you start the engine the speakers shut off again.
This is WAY beyond my capabilities and I've simply never heard of anything like this previously.
Ronlu
geepherder
Platinum - Posts: 3,668
Posted: May 24, 2006 at 8:38 PM / IP Logged
I've battled with a repair center back and forth with issues such as these.  If you can try another unit in the car and it works fine, chances are it's with the unit.  It also may be helpful to take readings of the wires while these conditions exist.  Check your constant, accessory and ground.  You can also check all your speakers/speaker wiring to make sure everything's okay (no blown speakers, shorted speaker leads, etc.).  Ohm the speakers out and make sure they're good.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
