2002 camry aftermarket head unit
stalt
Member - Posts: 23
Posted: May 26, 2006 at 12:36 PM / IP Logged
Just bought a 2002 camry.
Couple of questions.
How does the panel come out so you can replace the head unit.
is the wiring harness the same as the 99 - 2001?
What is the aftermarket bracket you need to fill in where the cassette went?
Do they look good?  have seen some units look real cheezy compared toteh factory install.
Thanks,
Stalt
xtremej
Gold - Posts: 1,440
Posted: May 26, 2006 at 2:32 PM / IP Logged
If you click this link and plug in your vehicle information it will tell you what you need. These are pretty good quality fit.
kgerry
Platinum - Posts: 3,455
Posted: May 26, 2006 at 4:13 PM / IP Logged
i usually just use Metra's Toyota pocket and ISO mount the new HU......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
